Air Foils, why some w/ holes and some w/o?
Old Feb 27, 2001 | 07:18 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I currently have an air foil installed that completely seals the "AIC port" I guess you can say. I recently aquired one with two holes at the bottom of the foil, allowing air into the middle "AIC port" area in the throttle body. How important is this and can this relate to my somewhat unstable idling? It varies from 500 to about 650 RPM during warm up. Up and down, up and down.
IROC-Zone - Coming Soon!
The Camaro Shrine
'88 Camaro IROC-Z 350 TPI
'98 Grand Prix GTP 3.8L SC
"Yea, though I walk through the valley of rice,
I shall fear no Turbo; for Torque art with me."
- Cullan Hooley
Old Feb 28, 2001 | 05:59 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
You need to switch out those airfoils. You definately need those holes so air can pass through to the IAC passages. By the way, what kind of airfoil do you have in there right now that doesn't have those holes?? I have yet to see one.... is it homemade?
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Feb 28, 2001 | 08:59 AM
Steve89GTA's Avatar
The Jet Airfoil has the holes...as far as other go, I'm not sure. I can remember seeing the TPIS on in a pic once and it did NOT have the holes.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Autometer Vac+Oil Temp
Old Feb 28, 2001 | 09:07 AM
Car: 1985 Trans Am
I HAD a TPIS airfoil in mine and it had a semicircle hole along the very bottom IIRC... I switched to the JET becuase of the sharper profile.
Kevin Irving
Old Feb 28, 2001 | 03:46 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I stand corrected. It does have a little hole at the very bottom.
I currently have the one like the one on the left installed. I like it because it's bolted in place, but it's not as smooth as the Jet (the one on the right). I have both. So now I'm debating on which one I want in there. The Jet looks much smoother and is a simple install, plus it looks like it allows more air into the AIC port area, whereas the one on the left doesn't look like allows much at all.
IROC-Zone
The Camaro Shrine
- Cullan Hooley
Pac J
May 17, 2020 10:44 AM
gta892000
Aug 11, 2019 11:16 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
BurlyChev
Aug 22, 2015 01:52 PM
L98FORM89
May 13, 2001 08:24 PM
