LT1 Injectors work on TPI?
Old Mar 2, 2001 | 08:35 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I have a chance to buy 8 24# injectors from a LT1, will these work on my '91 TPI? The OEMpart # is 17121068. Thanks.
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Old Mar 2, 2001 | 09:03 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Injectors are basically injectors with the exception of low impedance ones. Usually though they are high flow. Some of the LT1 injectors are 22 lbs and some are 24's. If you wind up getting 24's you will have to recalibrate the prom to compensate for the higher flow. But to summarize yes they will work.
James
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Old Mar 2, 2001 | 09:17 AM
Kevin G's Avatar
Yep, I used some 24# LT1 injectors on my L98.
Not that anyone would want to try this(wouldnt make much sense flow wise), but you cannot use the L98 injectors on an LT1 though due to their impedance.
[This message has been edited by Kevin G (edited March 02, 2001).]
1992rs/ss
Jan 31, 2025 05:10 PM
midge54
Dec 27, 2019 04:14 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
