MAF-code 33 WON'T GO AWAY!
Old Mar 2, 2001 | 10:29 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Initially, I had trouble w/ the MAF sensor filament staying "ON" w/ the ignition off (Oh, and of course the car ran like crap). So, I figured the MAF Burn-off relay was stuck in the closed/on position. Put a new Burn-off relay in and that fixed the filament problem, but I am setting a code 33 even after clearing the codes from the computer.
Any ideas, suggestions?
Thanks,
Neil
Neil's 383 IROC-Z: TPIS MiniRamIII / GM FastBurn heads / Strange 12Bolt Diff./ Neil's Home-Built BulletProof 700R4+Vigilante 2800 stall converter.
Old Mar 2, 2001 | 11:13 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Code 33: High voltage (low vacuum) at mass air flow sensor.
Check the TPS voltage, it should be .54VDC.
Change all the relays, and if u keep getting it, u need a new MAF. Have u modded it??
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
[This message has been edited by IROCZTWENTYGR8 (edited March 02, 2001).]
Old Mar 3, 2001 | 08:23 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
I had the same hard 33 code. This happened after I replaced the MAF and swapped relays.
Turned out that one of the female sockets on the MAF weatherpack was bent slightly out, so it was only making partial contact. I have a temporary fix on it, but I need to replace the connector.
89 Firebird Formula
WS6 package,ZZ4 Crate engine
SLP 58MM TB, Edelbrock TES Headers
Random Tech 3" cat, SLP 3" stainless exhaust
9 bolt rear, Hotchiss swing arms, Lakewood panhard rod
Corvette 2/4 servo, kevlar band, full poly rear.
Centerline 16x8 rims, B.F Goodrich drag radials
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
