Camshaft help
Old Feb 28, 2001 | 11:10 AM
MINN IROC-Z's Avatar
Car: 1988 IROC Z
Camshaft help
I am looking at getting a ZZ3 camshaft. Do I need to change valve springs with this cam? I am planning on staying with the factory rocker arms for now but am having the heads ported and one size bigger valves. I have already ported the intake and don't really want to have to update computer quite yet. I was going to get a ZZ9 camshaft from TPIS but they are a lot more than a ZZ3 and not much different on cam specs. I would greatly appreciate help on the spring question. Thanks.
Old Feb 28, 2001 | 04:10 PM
Dan87IROC-Z's Avatar
Yes, you will need new valve springs with the ZZ3 Cam. It has .509" of lift on the exhaust side and the OE springs are only safe till about .490" or so lift. I bought the valve springs TPIS sells for the ZZ9 Cam when I swaped in my LT4 HOT Cam, and even though I haven't really been able to drive my car yet, I am sure the new springs will work great. They cost me $125 and were delivered with in a week.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 5, 2001 | 11:05 AM
Beefy89's Avatar
You can get the ZZ3 springs for $33 or so from www.competitionproducts.com.Part # 10134358.
We need Perry Mason
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
