what side is everyones knock sensor on?
Old Mar 4, 2001 | 09:33 PM
bad camaro RS's Avatar
i did a tpi swap a while back and i put knock sensor on the passengers side but now i jus installed hooker long tubes and theres no room for it i tried to put it on drivers side but my plug in block wont come out any where else i can put it?
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10.9 to 1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos to be installed soon
Old Mar 4, 2001 | 10:06 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don't have long tubes, but mine KS is on the pass side, up above the A-arm
Old Mar 5, 2001 | 10:30 AM
87Z-ya's Avatar
if there is room you could drill a hole in the motor mount that bolts to the block, tap it and put the knock sensor there.
87z 383,afr 190's, comp hyd roller(242/248-.540/.562,114 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, tremec 5spd, , 1,3/4" slp headers, speed pro bank to bank-wb02.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Old Mar 5, 2001 | 02:22 PM
how would putting it in motor mount help? i want it to still work thanks
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
db057
Aug 22, 2015 08:17 PM
timonator
Aug 11, 2015 09:56 PM
gwade12
Aug 8, 2015 08:17 AM
