Runners and Manifold affect on fuel pressure?
Old Mar 3, 2001 | 12:05 AM
ADMZ24's Avatar
Car: 1991 Trans Am
I have a chance to get an eledbrock manifold ported to a pair of SLP runners. Will this mod help me?? I read somewhere that the increase in airflow would require an increase in fuel pressure, and that the injectors can only handle so much pressure. The guy also wants to throw in a fuel presure regulator. He said i would need it. I just got almost new injectors a couple of months ago. they are stock 19 pounders, how much pressure can they handle??? WHat pressure will i need with the intake mod???
1991 WS6 Trans Am
Dark Green Metallic
Camel interior
305 TPI
TH 700-R4, Auto
T-Tops, PW, PL, PM
Keyless entry, alarm
Flowmaster Muffler
Monza Dual Tips
K&N Filter
Old Mar 3, 2001 | 01:11 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
If you have a chance to get the regulator go ahead and get it. It's a good tuning aid for the price.
Chances are you won't need to increase fuel pressure though.
The factory PROM calibration is a little on the rich side while at wide open throttle. The only reason you would might be likely to need to adjust A/F ratio is to help with any loss of part throttle drivability.
The intake parts are a good upgrade. They can bolt on to a near stock engine as is and make a power improvement, and if you build up the rest of the engine more you can port them (or get them ported) to keep up with your mods. If you are geting a good buy, then have at it.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
Old Mar 3, 2001 | 09:42 AM
The ODB's Avatar
Irocz4me,
How is your hydro-rev kit doing? Have you got any test data from that yet?
ODB
Old Mar 5, 2001 | 12:29 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
A friend of mine has almost the same deal, and as mentioned we run a little rich. Part throttle driveing wasn't too bad either. Just now, when your doing 55 @ 1400/1500 rpms and kick-it in the rear to go around someone, it's gonna go like before but with more zing Personally, i say yea, get the AFPR to sqeeze the extra horses out. Every bit counts right?
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Old Mar 5, 2001 | 11:04 PM
IROCKZ4me's Avatar
ODB,
I like it. I don't have any hard numbers with & without on this engine application because I installed the current heads, cam & rev-kit at the same time.
I do know a rev-kit (another brand) made a big difference on a solid roller Chevy 302. It picked up top end big time. It was a much higher revving engine, but the solid rollers are lighter, the ramp profiles weren't as severe, and since it was a solid roller I could use stronger valve springs too.
This engine has a cam with a very aggressive ramp profile, heavy hydraulic rollers, & Crower 1.65 ratio rockers (rapid valve acceleration). All that adds up to a lot of valve train inertia.
The use of hydraulic lifters keeps me from using killer valve springs so the rev-kit helps make up the difference by taking a load off the valve springs.
The fit & quallity of the AFR rev-kit is excellent!
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • fully balanced
  • SLP cat-back
My IROC-Z
Club IROC-Z
[This message has been edited by IROCKZ4me (edited March 05, 2001).]
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
mdtoren
Aug 16, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
