what lift cam
Car: 87 iroc-z
Engine: 350 tpi motor
Axle/Gears: lsd 4.10
what lift cam
for the stock 305 what rang cam should i go for, will i have to put a bigger tb, sould i go with a 4.10
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: what lift cam
Do a search and see what cam other 305 owners are using.
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: what lift cam
With stock heads your pretty limited on a 'usable' cam range. Since the 305 is a low-end motor and you have a deep gearing, look at some cam sites like Comp or Crane and see their notes on the cams. They will tell you their range in RPM and where their suited performance is at. Low to mid range IMO is about what you should strive for. The TBI should be big enough right now. Also check to see what cam profile was on your year model. For instance the TPI 305 in 85 (1st year of TPI) had a better cam than the 86 motor. You may find a truck or another 305 cam that is cheap and will suit your needs. Look into heads too. World makes 305 SR Tourqers pretty cheap. SR means stock replacement, but they are a little better than stock And can be improved on as well. The stock heads on a 305 is a 58cc. Keep them 58 so your compression stays up there. When I still had my 305, I exhausted its limits of the stock heads/cam with everything else I could. Wasnt too bad, but it never would respond very well to all the mods like a 350
Car: 2000 BMW M5
Re: what lift cam
You can get a stock LT1 cam (around 0.450" lift) on ebay for cheap. I paid $40 for one with under 50k miles. That would be a great cam for a 305 w/ stock heads.
