MOTOR QUASTION
Old Sep 19, 2007 | 01:05 PM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
MOTOR QUASTION
I know that my car is a 1986 z28 but what motor is in it my aunt said that
she special orderd it late in 86 mt tach redlines at 5000 rpms I dont get it I have raced against good running iroc's and have beatin them with my car
my car also has a possi rear end which it isnt supposed to eathier
please let me know thank you what do you think my car runs in the quarter mile I know its fast I can spin first thrue third and yes it is a automatic
I really am curious what I would run with some slicks on it iam just afraid I would tweak the frame p.s i CAN FLOOR MY CAR AND GO WELL OVER 5500 RPM'S ??? PLEASE HELP ''IT IS A TPI MOTOR TO
AND A 10 BOLT REAR END WHICH i HEARD WAS UNCOMMON FOR MY YEAR
Old Sep 19, 2007 | 01:47 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: MOTOR QUASTION
If your 86's motor is orginal, then you have a 305 TPI motor. 10 bolt rear ends are common. To learn more about your car find the RPO codes under the center console lid and do a search on what you find.
Old Sep 19, 2007 | 02:54 PM
Car: 87z28
Engine: 70 LT1
Re: MOTOR QUASTION
then it must not be original then
we already ran the rpo codes on this site before and nothing matches what i have
Old Sep 19, 2007 | 03:15 PM
Wadebryant's Avatar
Re: MOTOR QUASTION
http://www.austinthirdgen.org/index.php?pid=30
http://www.austinthirdgen.org/index.php?pid=31
The links above should help you with the vin and RPO codes.
GM did not install 350's in pre-87 Camaro's. If the motor has been replaced, the only way of knowing what it may be is to get the numbers off of the front or rear of the engine.
Old Sep 19, 2007 | 03:23 PM
Car: 87z28
Engine: 70 LT1
Re: MOTOR QUASTION
already had the motor looked at when my heads wer done they said it was a 350 plus when I replaced my fuel pump it was for a 350 tpi my heads that are on my car are weird because the valve cover bolts are around the outside like the older style
Old Sep 19, 2007 | 03:28 PM
rice slyen 87's Avatar
Car: 87 iroc-z
Engine: 350 tpi motor
Axle/Gears: lsd 4.10
Re: MOTOR QUASTION
305, if its stock it wont burn though 3 if its a 700r4, and if you dont strip the rear end it will probaly run high 14 to 15, if it is what you say it is than dont take it to the track most likely your going to get a mad tick for the flex plate. i have an 87 and went through all the problem's your going through good luck man if your going to race this car start getting student loans to pay for it like i did,.
Old Sep 19, 2007 | 03:32 PM
Car: 87z28
Engine: 70 LT1
Re: MOTOR QUASTION
how come i can blow away iroc's that are factory and they have 350.all iam
saying is my motor shouldnt rev passed 5500 and it does its just weird
Wadebryant's Avatar
Re: MOTOR QUASTION
I'm not convinced that it isnt a 305. Centerbolt heads werent put into production until 87! Pre-87 heads have the valve cover bolts on the outside of the head (old school style). Many parts inter-change with the 350... and the 305 / 350 look just the same. Get dirty and find the casting numbers.
Good luck
Old Sep 19, 2007 | 03:35 PM
Car: 87 iroc-z
Re: MOTOR QUASTION
is it stock
Car: 87z28
Engine: 70 LT1
Re: MOTOR QUASTION
for some reaseon the garage i went to told me that it is a 350 .p.s they said my motor must have been changed at some point because the cam was changed in my car. T his is one of the reaseons why I wanted to just put another motor in it so i new what i was dealing with
no its got a small cam and a 1500 stall in it from b&m
Last edited by hung4wheeler; Sep 19, 2007 at 03:36 PM. Reason: Automerged Doublepost
Old Sep 19, 2007 | 03:39 PM
Car: 87 iroc-z
Re: MOTOR QUASTION
go to myspace.com/snatchcacic watch the vid that's a almost compleatly stock iroc-z tell me what you thik it would run. this is just to help you understand
Old Sep 19, 2007 | 03:41 PM
Car: 87z28
Engine: 70 LT1
Re: MOTOR QUASTION
The one iroc I raced said he ran a 14.2 in the 1/4 and I beat him bye a car .
so I dont know ive never been to the track .maybe you can give me your guess
Old Sep 19, 2007 | 03:48 PM
Car: 87 iroc-z
Re: MOTOR QUASTION
my car back than ran low 15's, with it i have blown away other i-roc's and bin beaten by v6 f-bodys, camaros are not fast stock you make them fast that why im fabing a twin turbo kit
Old Sep 19, 2007 | 03:50 PM
Car: 87z28
Engine: 70 LT1
Re: MOTOR QUASTION
my car isnt stock
Old Sep 19, 2007 | 04:16 PM
Car: 87 iroc-z
Re: MOTOR QUASTION
when your car burns out does one wheel spine or both
Old Sep 19, 2007 | 04:18 PM
Car: 87z28
Engine: 70 LT1
Re: MOTOR QUASTION
both burn up at the same time but when i checked my rpo codes my rear end is out of a 89 z28 iam baffled
iam starting to wonder if some one didnt do alot of work on this car including motor and rear end swap
it says my rear end is a GU2 rear 273 gears ..but MINE is a possi any b ody with a guess because the gu2 wasnt offerd according to the links i found for 86 but thats what my rpo code says
Last edited by hung4wheeler; Sep 19, 2007 at 04:22 PM. Reason: Automerged Doublepost
Old Sep 19, 2007 | 04:33 PM
Car: 87 iroc-z
Re: MOTOR QUASTION
i know what happend who ever had the car before had the same kinda powerful motor when they lunched the car the rear end blew up, than they got a junk yard rear end. and Its a 5.slow unless its a creat in 86 like 12 cars were made with the 350 and without a limmited slip you dont have one
Old Sep 19, 2007 | 04:37 PM
Car: 87z28
Engine: 70 LT1
Re: MOTOR QUASTION
so what was the GU2 rear end?? why does it say it was in my car on my rpo codes but when i checked it said that that gu2 was offerd in 89 ...?I must have the 350 that some one must have swapped in
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
