Blown ECM fuse = Bad ECM???
Old Mar 8, 2001 | 12:09 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Found out the ECM's fuse was blown and thats why it wouldn't start. COuld this be the reason for all my hesitation problems? Is the ECM going bye-bye?
'91 GTA:
www.fbody.com/members/91WS6GTA
Old Mar 8, 2001 | 07:49 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
It could indicate a short in the wiring harness (the most likely reason for the fuse blowing). And yes, this could cause poor running.
Old Mar 8, 2001 | 10:09 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
OK. Thanks Glen! Any idea how to find it? Any tricks? Any key locations? TIA
'91 GTA:
Old Mar 8, 2001 | 10:26 AM
Ski89Z28's Avatar
If it is a short with the wiring harness you could disconnect the ECM, all connectors to it, and make sure you replace the fuse and turn on the ignition BUT DON'T TURN OVER THE ENGINE. If the fuse blows the you COULD have a +12 volt line shorting probably to the frame. If the fuse does not blow the it COULD be the ECM. I said COULD on both of these cause when it comes to electrical problems anything goes.
I wish you luck cause you'll need it.
Old Mar 8, 2001 | 11:55 AM
Kevin G's Avatar
Also try tapping lightly on the ECM with the car running and see if it stalls out. What were your other problems before the blown fuse??
http://members.home.net/regulators/kevg.html
-=ICON Motorsports=-
Old Mar 8, 2001 | 12:26 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
OK, I'll try that. Read my "Code 33 stumbling" post below in the TPI stuff. Thanks
'91 GTA:
Ghettobird52
Jul 5, 2024 11:18 PM
stalkier
Dec 6, 2015 11:25 PM
mddaniel
Sep 8, 2015 05:16 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
