something happened?
Old Sep 19, 2007 | 07:41 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
something happened?
My engine just started popping through the air cleaner at idle and gets worse as I open the throttle body.
any suggestions?
thx
jeff
Old Sep 19, 2007 | 08:32 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: something happened?
Carbed?
Broken distributor, cam jumped a tooth, valve spring broke, very lean, blocked exhaust.
Those are the first things that come to mind.
Old Sep 19, 2007 | 08:35 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
or you just gave it a tuneup and have a couple wires not tight or in the wrong spot haha i've been there once or twice hehe.
Old Sep 19, 2007 | 08:40 PM
jjlabinski's Avatar
Engine: shinny 350
honestly I think it is a stuck valve?
what would this sound like?
thx
jeff
Old Sep 20, 2007 | 09:00 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
If it is an MAF TPI, it could be the MAF sensor. Though that would cause a nearly un-runable idling condition and would the make the car very difficult to drive period...assuming it even runs. This sounds like switched spark plug wires or timing is off.
Old Sep 21, 2007 | 03:58 PM
jjlabinski's Avatar
Engine: shinny 350
thanks...hopefully that is what it is cause it is maf
jeff
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
