My L98 does not have centerbolt valve covers?
Old Mar 7, 2001 | 04:48 PM
MrZ28's Avatar
I was wondering why my L98 does not centerbolt valve covers on it the other day when i was looking at it. could anyone help me out with this? it has all the stickers and everything on the vin says it is a L98?
Old Mar 7, 2001 | 06:09 PM
vortech305's Avatar
U possibly have an aftermarket head that uses universal valve covers or u may have an adapter kit which a company sells to use regular valve covers instead of centerbolt. Ive seen the adapter kit.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 7, 2001 | 10:33 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
What year is your car and what is the 8th digit of the VIN? If it in fact is an original L98 engine, then the valve covers have been changed as said above.
Old Mar 8, 2001 | 04:49 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its also possible somebody swapped the engine or heads in your car before you got it.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 9, 2001 | 08:56 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
From what ive learned about these models is that where ever you look on the car whether it be in the glove box at your assembly line options sheet or decoding your vin L-98's never came in any third gen it was called the b2l L-98's came with aluminum heads starting in 86 with the vette the easiest way to check if someone swapped heads is to look at the exhaust manifold or header it should have two accessory holes near the front of the head on the drivers side if it has one they are likley to be older production castings take a magnet to them and see if you have a pleasant suprise(aluminum)
Old Mar 9, 2001 | 11:07 AM
MrZ28's Avatar
Yeah it just had me wondering cause my car has L98 written all over it but those valve covers are not centerbolt. I really did not take it into serious thought until recently. Can you bolt the TPI intake to that many different heads? Ill go check today and see if they are aluminum or not. I hope they are cause that would be sweet...haha. It will probably turn out to be some 305 someone put in.
Thanks for all your help
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
New2Chevy
Sep 28, 2015 12:35 AM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
