would cleaning injectors help
Old Mar 9, 2001 | 07:26 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
I rescently have had a cold starting problem,the first time it happened I was in New hampshire and it was -10*,the coldest day of the year it took forever to get it going(started right after a monster backfire)and ever since I have trouble starting it when it's cold,I never had this problem before,and it runs the nuts once it starts
89 FORMULA 350,WS6 SUSPENSION,HOTCHKIS STB,KONI REDS,WONDERBAR,SLP REAR CONTROL ARMS/PANHARD,POLY BUSHINGS,FRESH 355 MOTOR,TCI 12" STREETFIGHTER,TRANSGO SHIFT KIT,3.70 GEARS,FLOWMASTER EXHAUAST,SLP 1 3/4 HEADERS,NO CATS,58 MM BBK,MINIRAM INTAKE,COLD AIR,ALL FREE MODS
Old Mar 9, 2001 | 10:27 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Remove your cold-start injector, clean the passage with Valvoline carb/TB cleaner, and reinstall (preferably replace, use a new o-ring). Be careful removing it. Make sure the injector is seated in ALL THE WAY or it won't want to run (vacuum leak). The motor will take a quick second to start (normal, because of the cleaner). Let it run for a minute or two, snapping it out occasionally to clean out the passages. This should help, check it the next morning. Be sure to take it around the block after doing this. You'll notice when you remove the injector the spray pattern(where the gas flowed)...if it's broad, you're OK; if there's a small river along the bottom, it's clogged. Mine was clogged. Check the bottom of the injector nozzle and the intake. Does it start like this when cold or every time you try to start it? If the motor is new, then this probably won't help, but it's worth a try. Change your fuel filter and check your timing too...it could be alot of things, so double check everything. Don't trust a stock damper...often the outer ring slips around the hub, resulting in faulty timing adjustments, leading to numerous 'unsolvable' drivability problems...
[This message has been edited by dhirocz (edited March 09, 2001).]
Old Mar 10, 2001 | 02:20 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
My car is an 89 it does not have the 9th injector(cold start valve)
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
