Stock cam specs
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I'm not sure, but I think its the 88-89 cam, which is 207/213 duration, .415"/.430" lift, and 117 lobe.
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
[This message has been edited by IROCZTWENTYGR8 (edited March 03, 2001).]
Looking For:
87 IROC-Z 350 TPI
Car: '89 GTA
Engine: ZZ6TPI
Scoggin Dickey is selling take-off ZZ4 cams for $100. Much bigger than the TPI cam.
89 Transam GTA, a few bolt ons
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You have a roller engine? I'd find an LT1 cam from a 4th genner. They have about the same duration, but the lift is higher. Or put an ad in the classifieds here, I'm sure someone has one they've taken out of their car.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I think I have one. I have an 89 vette 350 block with stock roller cam. I will be changing it out for a new one in a few weeks. I am not 100% sure it is the one you are looking for but it is definitely an 89' vette engine with roller cam.
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> B&M shifter, Extreme Energy 230/236 cam, Holley street dom intake.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, all stock.
1986 CAMARO Z28 ->
1987 TRANS AM ->
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Re: Stock cam specs
Would anyone have a source and part number? Looking for a stock replacement for an 89 IROC TPI roller (or maybe for a Corvette) as long as the computer will work with it. Will not be racing it
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Stock cam specs
10066049
thats the GM model/part number for the 89 TPI L98 cam which is 207/213. i have one that will be coming out of my motor in the next few days...good shape from what i can tell. 158K miles on it
the 90-92 L98 cam is this
10111773
10111773
