Trick Flow G2 heads
Old Mar 10, 2001 | 09:48 AM
88 trans-am's Avatar
Trick Flow G2 heads
I was told when I bought my trick flow heads that they all had crapy valve guides and would need to be reworked after 10,000 miles. I am now closing in on that mileage ,and they are still running great. I was wondering how many people loved ,or hated there TFS G2 heads.
Mike s
Old Mar 10, 2001 | 09:55 AM
The ODB's Avatar
are yours the twisted wedge design or inline valves?
Old Mar 10, 2001 | 10:43 AM
MY heads are the Trick Flow G2 twisted wedge head for 87 and up.
Mike s
Old Mar 10, 2001 | 11:10 AM
The ODB's Avatar
I think some people have trouble with guide wear because they don't use the correct length pushrods with the twisted wedge heads.
The intake valves are offset and are further from the lifter than the exhaust valve. This requires a slightly longer pushrod (intake) to keep the correct rocker geometry. This means that you need two different length pushrods with those heads.
If the rocker geometry is off then there will be greatly increased guide and seat wear.
I've run my twisted wedge heads since 1996 and had no problems with guide wear yet.
Old Mar 10, 2001 | 11:40 AM
james_fearn's Avatar
are the 23* twisted or inline? I imagine they are inline because nowhere is canted mentioned anywhere in their information, but then again they've gotten a lot of grief over the problems associated w/ their canted (twisted wedge style) heads.
James
Old Mar 10, 2001 | 11:52 AM
The ODB's Avatar
twisted wedge means they are canted.
Old Mar 10, 2001 | 12:12 PM
I know, I have a pair for my mustang 5.8 EFI and with my former 351C, but are the 23* canted?
James
Old Mar 10, 2001 | 10:36 PM
I have been told that I might have to use two difernt length pushrods,but when I put this motor together I mesured both intake and exhoust and both were ok. The 23* are not wedge heads.
Mike s
Old Mar 10, 2001 | 11:23 PM
superiroc's Avatar
I got the wedge heads and love them and I'am well past the 10k mark with g1 heads!
Old Mar 11, 2001 | 07:24 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
The G2's should be fine. The problem was on the G1's. I just had my G1's rebuilt. As far as I can tell, there are several problems, one which I created. The springs suck. I broke 10 inner springs with a mild cam. And you need proper valve train geometry to protect the guides. (my fault for not checking). Although in my defence it was the exaust valves that were bad, not the intake, which is the different one.
FWIW, the G2's & G1's are canted or Twisted. The 23* are not.
Bob '89 Ram Air Formula 350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old Mar 11, 2001 | 08:02 AM
Dan W's Avatar
I talked to a local machinest a while back about this. He said installing bronze guides takes care of most of the wear problems and considers it manditory for TW heads.
Old Mar 12, 2001 | 01:09 AM
F22Raptor's Avatar
Which are beter as far as power, the G2 or the 23* heads
Rick
'88 GTA 350 Full of Leprosy (rust)
Headers, catback, free mods, Xtreme energy cam, intake pieces and 2100 RPM TQ
13.39@102.50 MPH
1.90 Sec ----- Best 60FT
104.23 MPH -- Best Trap Speed
AIM HIGH!
Pac J
May 17, 2020 10:44 AM
69GTOby
Apr 18, 2016 02:34 PM
dusterbd
Sep 29, 2015 08:40 AM
ssgt usaf
Sep 21, 2015 12:45 PM
hdis2002
Sep 8, 2015 02:52 PM
