Which spark plugs does anyone suggest for my application
Old Mar 11, 2001 | 06:27 PM
vortech305's Avatar
U can see my modification from my sig. and help me figure what spark plugs to run. I have bosch plattinum and people have told me to change them, but what exactly should i get. People also have told me to get rapid fire plugs but also told me then run out to fast. So in conclusion which spark plugs should i get and at what gap should i put them in for performance and regular driving.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 11, 2001 | 08:00 PM
Dan87IROC-Z's Avatar
AC/Delco Rapid Fires are the best plugs I have ever used. I give them a gold star!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 11, 2001 | 08:30 PM
JETHROIROC's Avatar
AC R45TS. When you get the blower on there, use AC R43TS since it's a colder plug.
Old Mar 11, 2001 | 08:34 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i've been using the bosoch plat.for years and i've never had any kind of problem.now if you run nitrous you shouldn't run the platium plugs.unless you run a MSD box(or some thing like it)your really not going to see any difference opening the gap any wider than .035.you may see a loss in power if you do widen the gap.if you do run a MSD box they say you can go as wide as .060 but that is some thing you'll need to paly around with
1991 banditt2 #130 of 600
Project 350 Banditt
<A HREF="http://clubs.yahoo.com/clubs/streetdawgracing" TARGET=_blank>
http://clubs.yahoo.com/clubs/streetdawgracing</A>
http://y42.photos.yahoo.com/tonysams72.
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Mar 12, 2001 | 12:20 AM
The ODB's Avatar
Autolite #51
if they fit your heads.
.032 gap
[This message has been edited by The ODB (edited March 11, 2001).]
Old Mar 12, 2001 | 06:56 PM
vortech305's Avatar
thanks for all your answers, and i guess my friends 91' camaro has a problem cause he has a modified 355 SB with edelbrock heads,edelbrock intake air gap,comp cams Every part of MSD(ie,box,plugs,distributor,cap and coil,ect.)and he attends Lincoln Tech and one of the teachers advised him to try running .80 gap on his rapid fire plugs. His motor is modifid like crazy and hes running somewhere in the 400-450 RW horsepower and im guessing the .80 gap is too much
Old Mar 12, 2001 | 07:00 PM
91banditt2's Avatar
Engine: 5.7 HSR
.080 gap?damn that's a lot
Project 350 Banditt
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
