injector?
Old Sep 24, 2007 | 05:50 PM
91chevyz28's Avatar
Car: 1991 Camaro Z28
Transmission: 5 speed
Axle/Gears: alunimum drum limited slip 3.08
injector?
how do you test the injectors?91 stock 305.is there a test you can do w/ a volt meter?
Jason
Old Sep 24, 2007 | 09:34 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: injector?
yep. remove the connector and test the resistance between the two prongs. should be between 12 and 16 ohms. there are others as well. a search should be able to locate them.
Old Sep 24, 2007 | 10:12 PM
91chevyz28's Avatar
Re: injector?
Thanks!
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
