TIMING
Old Sep 24, 2007 | 09:32 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
TIMING
Are you suppose to dissconnect the timing connector before setting the base/intial timing. I was told if you don't you can screw the ecm up or worse!
Also what do you guys have yours set at for a fully modified tpi
Last edited by Americanmouse; Sep 24, 2007 at 09:34 PM. Reason: Automerged Doublepost
Old Sep 24, 2007 | 09:39 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: TIMING
yes....disconnect it before you set base timing or you will be fighting the ecm the whole time.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
