305 TPI and L98 Vette heads...
Old Mar 6, 2001 | 05:15 PM
MatthewH's Avatar
Hello,
I posted here a while back about using L98 aluminum heads on the 305 going into my Volvo 740 sedan. My main concern is EGR since I live in New Jersey which is quickly becoming the east coast equivalent of California. Did the F-body cars ever have the same EGR system that the Corvettes did? I've seen F-body exhaust manifolds with some sort of tubing coming out and leading to the intake. Could this be used in conjunction with Vette heads and exhaust manifolds (or headers)?
Thanks,
Matthew C. Hall
Old Mar 8, 2001 | 02:50 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
The vettes didn't have an EGR system, the heads aren't designed with egr. The tube coming form the manifold is probobly for air injection and not leading to the intake. I run the vette heads on my stock tpi and have no problems. Just leave the egr valve on the manifold so it will pass a visual check, then make sure it runs good and it may pass a sniffer.
good luck.
'88 RS (originally 2.8)
New 350, .040 over, ported vette L98s, ported stock tpi.
Old 305 injectors & chip
TES headers, 3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
(Damn the 2.8!)
Old Mar 8, 2001 | 04:44 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Here's what I did:
http://24.1.139.249/images/021701/
Thats a set of SLP 1 3/4" headers specially modified by my dad and I to use the Corvette EGR with the Corvette heads. That setup is how the Corvettes have their EGR.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 8, 2001 | 04:46 PM
MatthewH's Avatar
The Corvette definitely has an EGR system as do all cars manufactured in the past 25 or so years. In John Baechtel's TPI engine swapping book it shows the Corvette intake with the rear mounted EGR port. From what I've found in the archives a system can be fabricated by tapping a line from #8 cylinder at the manifold to the Corvette manifold to rectify the problem. Has anyone else done this?
Thanks,
Matthew C. Hall
Old Mar 13, 2001 | 05:05 PM
Car: Damn
Engine: This
Sorry, your right. the vette's had egr, just a different setup. I was meaning the heads didn't have egr provisions, you's have to do setup like the vette has. My bad.
(Damn the 2.8!)
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
