Fuel PSI
Old Sep 25, 2007 | 01:32 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Fuel PSI
l98 350
1:6 rockers
K&n filter
3" catback
Air Foil
How much idle fuel psi with vac. lines CONNECTED?
I got it at 40psi.. spikes to like 48 WOT... this good?
Old Sep 26, 2007 | 04:55 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Fuel PSI
It's fine.
Old Oct 3, 2007 | 06:10 PM
SLP_GTA's Avatar
Re: Fuel PSI
Mine pressure conected is 35psi, spikes to 38. I'm having cold only hard start problems, so does that mean my pump getting weak??
Also if I turn the key quickly it starts cold, if I slowly turn on the key, it will not start. what do you think the problem is??
FYI I replaced the fuel filter and relay.
Old Oct 4, 2007 | 05:36 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Fuel PSI
Your pump could be getting weak. Could also be leaky injectors or regulator.
No clue on slow key turns.
Old Oct 6, 2007 | 10:19 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
Re: Fuel PSI
yeah your psi is right where it should be... you could actually maybe bump it up to 42psi idle, 50psi WOT... from stock psi to 50psi wot it has dyno proven 30ft/lbs on a stock l98
9192camaro
16
Feb 3, 2019 12:21 AM
fasteddi
Sep 2, 2015 10:29 AM
355sbcTPI
Aug 19, 2015 04:38 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Kaweh
Aug 9, 2015 02:54 PM
