looking for LB9 heads but which ones?
Old Sep 26, 2007 | 01:54 AM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
Hello,
Im looking for some LB9 heads for a 305 but didn't know if there were castings out there that were better preforming heads then others. Could any of you tell me what casting I should be looking for? Also how much do these heads go for? Thanks
Aaron
Old Sep 27, 2007 | 02:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: looking for LB9 heads but which ones?
The LB9 305 TPI casting number is 14101081. They were on 87-92 305 TPI engines, as well as 87 LG4 engines.
Old Sep 27, 2007 | 03:38 AM
Pat Hall's Avatar
The 081 castings are a decent, stock style head. If you wanted to upgrade a little further, maybe look into a set of the aluminum 113 casting corvette heads, or the World Products S/R Torquers with the 58 cc chambers.
Old Sep 27, 2007 | 07:56 AM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
Great, thank you very much for the info that I needed!
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
