Hot cam selection???
Old Mar 14, 2001 | 05:38 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Just found an Accel Super-ram and some 'Vette heads to go on my 355...The Super-ram has been ported and the heads have as well...The heads are off of an '87. I have been told the SR flows around 300 cfm (wow!)and the heads 233 cfm...I don't know how accurate these #'s are, though. I am aware of the flow restriction, I could always use them on my 335. I may opt for TFS heads. Anyway, I was going to use a Crane Compucam 2040. I looked into it- It's just a step hotter that a 350 TPI 'Vette cam. Not hot enough for me. I thought about it, and figured a cam around 275/285 duration w/.500" lift would be about right. 112 LSA should be OK. I just don't want to drop in any cam, I'd like suggestions on known, proven TPI cams. Something computer-friendly. I'm looking for a 2250-6000 RPM powerband, N/A, and a fair ldle. Other equipment I'll be using is a T-56, 3.73's, MSD, 1 3/4" headers and a 52mm TB w/airfoil (may go 58mm?). Looking for about 450 HP. I may decide on a blower in the future, but not right now. My block is hyd.flat tappet but I may convert to roller if I won't go bankrupt. I prefer roller, anyway. Anybody successful with any hot TPI street cams? Still looking after mileage. -dhirocz
[This message has been edited by dhirocz (edited March 14, 2001).]
Old Mar 14, 2001 | 08:50 PM
Dan87IROC-Z's Avatar
With your extensive list of mods, I would look at several cams. I have been very happy with my LT4 HOT Cam. I bought it from www.gmpartsdirect.com for $185 with shipping. TPIS makes a wide selection of cams. The ZZ9, ZZ9-X and others have been proven to work well, although these cams will cost you close to $400, you can look at the specs of these cams at the TPIS web site www.tpis.com. You can also consider the larger of the 2 SLP Cams in Summit. My friend is very happy with his SLP cam. The sites are www.summitracing.com and www.slpeng.com, I hope this helps!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 14, 2001 | 09:14 PM
Vader's Avatar
DH,
Don't forget that Comp has sixty pages of SBC camshafts, for whatever setup you want, and about fifty years of cam design experience. They might at least have an idea of what would work well for you, I would think.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 14, 2001 | 11:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Look at the cam tech article on this website for lots of cam suggestions.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
angel2794
Sep 8, 2015 06:22 PM
f-bodyz28
Sep 2, 2015 05:03 PM
masonta
Sep 1, 2015 06:40 PM
theurge
Aug 21, 2015 12:46 PM
