Fuel Rail Fittings
Old Mar 15, 2001 | 08:21 PM
S10Wildside's Avatar
Fuel Rail Fittings
I'd like to put braided stainless lines on my engine. What fittings will I need at the fuel rails? Do I have to be concerned with high pressure?
1982 S-10 Wildside
355 TPI, Accel High-Flow Intake, Ported Plenum, Arizona Speed & Marine Runners, TPIS AFPR, Edelbrock BBK 52MM Throttle Body, 1993 Typhoon Drivetrain
Old Mar 15, 2001 | 08:48 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I have the Accel TPI fuel rail fitting I got from Summit. They are made to accept -6 AN braided lines. I never used them because the braided line was too expensive for me. It's 29.99 at Summit. Their part number is ACC-74730.
I'll let mine go for $20 shipped.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
