Can I run ??
Old Sep 28, 2007 | 08:06 PM
CamaroSpeed's Avatar
Car: 1987 IROC
Engine: 305 Tpi
Transmission: 700r4 With B&M Rebuild Kit & 2800 S
Can I run ??
can i run 22lb injecter's instead of 19lb injecter's what do u think. what AFPR pressure should i run with the 22lb injecter's 1987 305 tpi
Old Sep 28, 2007 | 09:02 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: Can I run ??
as far as i know you would need to burn a new chip with injector size changed.
Old Sep 28, 2007 | 09:20 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Re: Can I run ??
you CAN, why do you want to?
Old Sep 28, 2007 | 09:54 PM
Car: 1987 IROC
Engine: 305 Tpi
Re: Can I run ??
I think i have a bad #4 injecter
Old Sep 28, 2007 | 10:29 PM
Engine: 350 SBC TPI
Re: Can I run ??
the 22s will make it very rich unless you modify the injector size on the PROM. No advantage but with the code fix yes, you can run them.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
