performace tpi runners or throttle bod?
Old Sep 26, 2007 | 07:06 AM
86transamkid86's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: ?
Axle/Gears: 2.73/stoke/soon to be 3.47
Which one would be the better 1 st. Up grade? And what is the diff. In performace between holly 58 mm throttle body and a bbk? Beside the price lol I have an 86 305 tpi
Old Sep 26, 2007 | 07:20 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: performace tpi runners or throttle bod?
both are fairly pointless at a stock setting honestly but, the runners are definetly a better upgrade for later on if nothing else.
Old Sep 26, 2007 | 10:03 AM
Stephen's Avatar
Car: 87 GTA
58mm on a 305? You looking to SLOW your car down?
Old Sep 26, 2007 | 10:19 AM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Forget those Mod's unless you are planning on doing some serious work later. Buy a nice set of headers and a cat-back, you will see more gains and it will benefit you even with your current stock setup. Trust me
Old Sep 26, 2007 | 11:53 AM
Car: 1986 trans am
Engine: 305 tpi
Transmission: ?
Well I already have a cat back I am gettin headers as well, and I am also gettin slp intake system so I have about 400 dollers left so I needed to know what one would be a better up grade so what you guys are sayin that not one of those parts will be better then the stock tpi runners and stock throttle body and I'm also gettin hypertech performace chip to go in to the car. So what kind of work should I get done to it then???????
Old Sep 26, 2007 | 12:23 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
dont get a hypertech chip.
with the extra 400$ i would opt for a cam swap, something like a lt1 cam would definetly be more fun than the stock cam, then i'd probably buy a set of cheap 1.6 full roller rockers.
After that or instead of that i would pickup another tpi intake and port it out and siamese it and all that good stuff, then you can just install it in place of your stock 1 later on after the cam swap (after a cam headers and some free mods the porting will definetly be a huge help).
Old Sep 26, 2007 | 12:37 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The larger TB's only help in the very high up rpms, or very modified motor. IMO that would be the very last thing I would get. You can get a better "bang" for your buck elsewhere in a mostly stock motor.
Old Sep 26, 2007 | 03:43 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Save up that money for a set of heads and cam or something like that. The TPI on a 305 is not as much of a bottleneck as if it were on a 350. You will see miniscule gains if you poke around with the stock intake system. 58MM tb is out of the question though, that is way overkill. You only need to increase the amount of air coming in once you have a combo that needs more air than is getting put in. This is not the case for you right now, your air volume being taken in is adequate as of now.
Old Sep 27, 2007 | 02:16 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You can put an LT1 cam or 1.6 rockers on the stock cam, but you cant do both on the stock heads. There isnt enough room in the valve springs.
Old Sep 27, 2007 | 03:33 AM
Pat Hall's Avatar
If you spend over $300 for a 58 mm TB, and whatever amount for a "hypercrap" chip, use whatever money you have left to buy a good bullet to shoot yourself in the foot with. Seriously though, if you're just trying to decide between runners or a 58 mm TB, there's no question that the runners would be a better investment. I have to agree with GuitarJunki though, the TPI system isn't extremely restrictive on a 305 motor, so your money would be much better spent on a good cam, or more exhaust upgrades. You could also score a good used set of the corvette aluminum 113 casting heads for that $400 if you shop around a bit. Heads, cam, or exhaust stuff will definitely make a lot more difference than the other things.
Old Sep 27, 2007 | 02:40 PM
Hell, with the amount of money he is looking to spend, on a 305 I vote for the best upgrade as a set of higher ratio gears. UNLESS of course, you have the optioned 3.42 gears, but you have to check the codes on the inside door. With a lack of other engine mods (heads, cam, increased bore and stroke), your engine is content with the amount of air you are giving it right now.
Old Sep 27, 2007 | 08:43 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
does anyone know of any after market headers that wil take those air lines for the air diverter valve. my stock headers have like al these metal airlins pribing into them and not sure if i can even replace them with new headers.
Old Sep 27, 2007 | 10:19 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
I'd spend the money on an MSD plug and play pro billet distributor, and a blaster coil.
Gears would be the best deal, though, if you don't already have them.
Old Sep 28, 2007 | 06:39 PM
88transam400tpi's Avatar
Car: 88transam/ 86 iroc-z/ 64 corvette
Engine: ta 400ci tpi/ iroc 327 / vette 327
Transmission: ta 5 speed/ iroc 700r4/ vette m-22
Axle/Gears: ta 3:42/ iroc 3:73/ vette 4:11
if you siamese the base intake. will it run ok on a 305 i thought that it might be to much for the 305 i am building a 305 now i was going to do that to the base but i figured it would kill my torque
Old Sep 28, 2007 | 07:54 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
For the best bang for the buck, I would put in a shift kit. I have one and would never go back.
Old Sep 28, 2007 | 11:09 PM
Kevin91Z's Avatar
Hooker Headers part number 2055.
Old Sep 29, 2007 | 12:30 AM
ParkerTPIz's Avatar
i would go with a set of slp runners
SLP RUNNERS=bolt on horsepower
and a + is if you ever decide to upgrade to a bigger motor....you can swap the whole TPI setup onto it.....(you would just have to buy bigger injectors, and get a prom burnt)
but anyway, i would rather buy an upgrade that is "re-usable" EX: if u bought a cam for your 305, you wouldnt want to/ be able to use it in a 350....
stalkier
Dec 6, 2015 11:25 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
