Best Bang for buck mod??
Old Feb 25, 2001 | 09:21 PM
TPI400guy's Avatar
Just wondering what everyone thinks the best bang for buck mod is. And Nitrous does not count thats just cheating!!
Old Feb 25, 2001 | 09:40 PM
The ODB's Avatar
Free weight removal.
Old Feb 26, 2001 | 02:46 AM
Dan87IROC-Z's Avatar
If you are talking that some sort of dollar amount you can purchase and get the most horsepower/dollar I would have to say exhaust mods. A full exhaust can cost just at or below $600 and can greatly inhance ANY car. My friend even wants to put exhuast mods on his freakin Infinity, thats how much they help!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 26, 2001 | 03:11 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
AFPR, and free mods.
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Old Feb 26, 2001 | 03:44 AM
WS - 666's Avatar
Cam + heads and/or porting.
Failing that, suspension work--cuz power's worthless if you can't put it to the pavement.
Old Feb 26, 2001 | 03:35 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
It depends on the car and your wishes.
like if you want to keep it emissions legal and keep stuff pretty much the way it is Id say something like exhast or a cam would be the way to go.
but if you dont care then the cheapest thing to do would be to go to a swap meet and pick up a 650 carb and intake and cheapo headers and youll gain tons of HP over most FI systems.
botom line is it takes more money to go fast on the TPI than just by swapping to carb.
Old Feb 26, 2001 | 04:49 PM
TPI400guy's Avatar
I hate carbs. I like getting 20MPG and not having to tune the damn car every couple days. By the way i don't have a car i have a S10 but the similarities are amazing between the two vehicles. So what im getting here is that if you don't want to go into the motor the exhaust is one of the best mods. I posted in the exhaust fourm. I figure i should run about a 3" headpipe down to a 40Series Muffler (no cats) into dual 2.5" pipe running out back.
Old Feb 26, 2001 | 06:16 PM
The ODB's Avatar
TPI400,
I love running a carb for the same reasons that you state for hating carbs.
just wanted to say that. How good a carb works for you depends on how good you work with it. a new saying.
same goes for TPI though.
Old Mar 8, 2001 | 08:06 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
headers
1991 banditt2 #130 of 600
Project 350 Banditt
<A HREF="http://clubs.yahoo.com/clubs/streetdawgracing" TARGET=_blank>
http://clubs.yahoo.com/clubs/streetdawgracing</A>
http://y42.photos.yahoo.com/tonysams72.
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Mar 8, 2001 | 08:49 PM
89GTA350's Avatar
Hedders, exhaust and air induction. Let your engine breath, that's the first mods.
89 L98 GTA
- Custom made air induction
- Headman Hedders (t.e.m.s.)
- Dynomax Race Magnum muffler
- TH700-R4 with vette servo and Superior shift kit
- All the rest is stock
james_fearn's Avatar
heads.
James
[This message has been edited by james_fearn (edited March 08, 2001).]
Old Mar 8, 2001 | 09:11 PM
98_1LE's Avatar
Stall conveter and drag radials
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Mar 8, 2001 | 11:01 PM
TPI383's Avatar
Porting work on the lower intake. Siamese the runners. Get super-ram - like performance for nearly nothing. add a K&N, a 180 stat, and a tune-up. chip gets 25 more HP... but don't get it from a vendor. look around the list for folks who will do one for ten bucks (no not me). Leave everything else alone and enjoy better ET's thru 150k miles with 45 - 55 more peak HP then stock, with gains thru almost the entire RPM range. $120 including machine work... port it yourself with a $29 jeggs sanding kit and alot of hard work with a (hacksaw??).
*OR* you can go on and get another 80 HP with another $2000-$3000. you'll probably do it, as its addicting once you get started. ;-) Once you have that much HP.. time to bust that 80K mile tranny or a rear. get out the wallet. Nitrous dealers should give the NOS kits away for free, and "happen" to sell rears and trannys and blocks. LOL.
Old Mar 16, 2001 | 04:57 PM
MouseCamaro305's Avatar
nitrous isnt cheating, and the best bang for buck is a good rear end gear or a nice stall converter, both work awesome together though
Old Mar 16, 2001 | 09:03 PM
The ODB's Avatar
I already stated the cheapest bang for buck mod.
The next would be a used nitrous system for about $100, and then some used slicks for another $100.
The weight reduction can be free.
There is $200 to $300 in parts and some work to give you at least a 2 second improvement in E.T. if not more.
There is nothing else that can compare.
*power comes and goes, but dead-weight is gone forever* (tm)
Old Mar 17, 2001 | 08:22 AM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
<font face="Verdana, Arial" size="2">Originally posted by 89GTA350:
</font>
have you taken you car to the track for results on your mods?
I am from Montreal...we should hook up..I am starting to look for mods to do to my GTA
89 GTA 350 T-Tops White/Grey----Looking for a little more performance than stock!
Old Mar 17, 2001 | 09:43 PM
pat85yellowroc's Avatar
gears and stall converters dont always make things better. depends on what you already have and what youre engine is. if you have a high rpm engine though, gears and stall converters can make a huge difference.
Old Mar 17, 2001 | 11:26 PM
Vader's Avatar
I'll throw in my vote for a higher stall RPM torque converter on an automatic, or taller gears on a manual.
The TC is cheaper, and will make the most dramatic acceleration improvement, dollar-for-dollar. A gauranteed rebuilt GM converter with a 2,200 RPM stall speed can be had for about $175.00.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
BrianI
Oct 3, 2015 12:57 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
