problems with idle......
Old Mar 16, 2001 | 08:45 PM
randal66's Avatar
my car runs fine at high RPM's but when i let off the throttle the RPM's drop below 500 Rpm and the car dies. sometimes it will idle at about 500 but when you put it in gear it will die out unless you hit the gas right away. anyone had this problem before? any help would be apreciated.
1987 trans am GTA
350 TPI
Old Mar 16, 2001 | 08:53 PM
The ODB's Avatar
check out your IAC.
Old Mar 17, 2001 | 12:21 AM
randal66's Avatar
whats the IAC?
Old Mar 17, 2001 | 12:59 AM
ArnoldBraker's Avatar
The IAC stands for Idle Air Control. It's a little stepper motor right under the throttle body. To m knowledge, it helps control the amount of air the engine gets at idle. When they get clogged and dirty, the car often does what you described. There is a good tech artice about fixing it and adjusting the TPS here: https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Hope That helps. ~Arnold
Old Mar 18, 2001 | 02:36 AM
BryanJ's Avatar
When my car was doing the same thing i replaced the egr and some vaccum lines and that fixed it....
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
