AFPR ? are they really needed?
Old Mar 18, 2001 | 10:55 AM
cc rider's Avatar
I have a basic stock 5.7 1991 GTA with ported plenum,air foil,SLP cold air induction,3" catback& MAT relocation.Do I need to raise my fuel pressure above 42psi.Glenn 91 L98GTA,we have the same car,any input?
[This message has been edited by cc rider (edited March 18, 2001).]
Old Mar 18, 2001 | 11:46 AM
Vader's Avatar
CC,
In theory, your relocated MAT should already be giving you slightly wider injector pulses. On the other side of the coin, the air foil might help air flow at WOT, which could cause a need for some enrichment. The freeer-flowing exhaust also helps air flow through the system, indicating the potential need for a bit more fuel. And the cold air intake adds to the situation.
If you did install an AFPR, any adjustments you might make would likely be minimal. Couple that with the acceptable variation in the factory flow ratings of injectors and the variation in stock fuel pressures, and you might be dead on accurate or way off the mark. The best way to tell would be with ET runs, an EG Ananlyzer, or an A/F meter. Unfortunately, the easiest way to change the WOT mixture is with an AFPR (there are many other, more difficult ways).
You can build your own AFPR for less than $1.00 (Can or US):
AFPR,pdf
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
[This message has been edited by Vader (edited March 18, 2001).]
Old Mar 19, 2001 | 01:57 AM
The ODB's Avatar
nope
Old Mar 19, 2001 | 04:41 AM
F22Raptor's Avatar
I don't think it should be one of the first mods
Rick
'88 GTA 350 Full of Leprosy (rust)
Full Exhaust, Free mods, Xtreme Energy cam, Intake Pieces and 2100 RPM TQ
13.39@102.50 MPH
1.90 Sec ----- Best 60FT
104.23 MPH -- Best Trap Speed
AIM HIGH!
Old Mar 19, 2001 | 10:30 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i agree maybe after you do some other stuff like headers and exhaust upgrades
1991 banditt2 #130 of 600
Project 350 Banditt
<A HREF="http://clubs.yahoo.com/clubs/streetdawgracing" TARGET=_blank>
http://clubs.yahoo.com/clubs/streetdawgracing</A>
http://y42.photos.yahoo.com/tonysams72.
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
