Sensor and Emissions compatibility
Im doing a tpi conversion on a tb vehicle using the 730 ecm,am told alot of the tb sensors and emissions will work,but should i change sensors and emissions to 730 ecm.vin i was given for scanning was 92 camaro.Would it make a differance? Thanks Mike
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey MIKE, you can re-use the MAP sensor, CTS sensor, AIR divertor/Canister purge solenoids, O2 sensor, MAT sensor. You will have to change the TPS sensor, KNOCK sensor, IAC sensor. If money isn't to much of a problem, it is always best to start with NEW WORKING SENSORS. This will make your life much better. HTH
BTW, this is my
500thpost
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed/1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
BTW, this is my
500thpost
Re: Sensor and Emissions compatibility
Hey, I didn't want to start a new thread and waste room so to speak. Just curious if emissions parts from a '90 are comparable with an '83. Canister, purge valve, ect... I'd like to buy new but I haven't found reasonably priced parts yet and I'm eventually swapping out my 305 for something less comical...lol
Hotrodboba400
Dec 10, 2019 07:07 PM
86White_T/A305
Sep 21, 2015 05:28 PM
