Need Help with Voltage Check
Car: 1989 GTA
Engine: 5.7 w/Paxton
If anyone has their ECM laying in the passenger floor board I could really use your help. I need someone to unplug their MAF and then probe B12 at the ECM terminal (green wire) and ground it to the ECM case and post the voltage reading. Help with this would be GREATLY appreciated. Thanks.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need Help with Voltage Check
Maybe
http://www.chevythunder.com/fuel%20i...ecm%20#1227165)
ECM key on and running Volt values there
Car: 1989 GTA
Maybe
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
On the tpi maf the signal is based on 5v ref. 5v being the max being 255gps. At idle 9 GPS is .73 v, 11gpis .91v and so on.
Car: 1989 GTA
