Failed emissions!!!! Too much CO!!!!!!!!
Old Mar 15, 2001 | 12:07 PM
FormulaGod's Avatar
Damn it, i was so close too. I failed CT emissions for too much CO (Carbon Monoxide)
Now does this mean im running too rich, or too lean?
I have an adjustable fuel pressure regulator, so i wanna play w/ that. Any suggestions?
"Restore decency in America. Ban rice!!"
Moderator at www.Lastgen.com check us out!!
Old Mar 15, 2001 | 12:15 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
Do you still have the AIR injection on your car? I don't and kept failing the CO test. What I eventually did was drop the fuel pressure to about 38 psi and put new spark plugs in (even though the ones in there were only about 10 months old). I also put a bottle of that ISO-HEET fuel line dryer/antifreeze in about a 1/4 tank of gas. I heard that this may help so I tried it. After doing all this, I passed easily. Oh yeah, make sure your car is running hot when you get it tested. The hotter the better. Just make sure it doesn't overheat.
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Mar 15, 2001 | 01:26 PM
Steve89GTA's Avatar
I don't have my AIR pump connected to the manifold either. I failed the first time b/c of CO. Since I still have the pump on the car I connected it directly the line that goes to the cat which basically pumps fresh oxygen into the exhaust and I passed. Simple but it worked.
Thougts?
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Mar 15, 2001 | 08:02 PM
evilho7810's Avatar
Try retarding your timing a few degrees if you only failed by a little bit. Otherwise it's probobly your cat.
Old Mar 16, 2001 | 10:18 PM
DON 88T/A's Avatar
Assuming your emission equipment is hooked up play with your timing and fuel...could be the cat
Old Mar 20, 2001 | 11:15 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Too much CO? How old is your air filter? Try a new one in there anyway.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 20, 2001 | 05:08 PM
RegalEagle86TA's Avatar
Too rich - The engine needs more air in order to fully burn the CO and oxidize it into CO2.
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
6998poncho
Sep 25, 2015 02:56 PM
