will i have problems with long tubes and TPI?
Old Oct 2, 2007 | 09:01 AM
SatisTraction's Avatar
I have put a 92 TPI engine into a 85 truck and I am down to the exhaust. The stock camaro manifolds will not work and neither will the truck ones. I am looking at some 1 5/8" stainless long tube headers that should fit fine. the question is how will it effect the performance? I prefer not to mess with any tuning isssues.
thanks
chris
Old Oct 2, 2007 | 09:22 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: will i have problems with long tubes and TPI?
You'll probably need to also consider having a 02 bung added into your header selection.
Old Oct 2, 2007 | 09:44 AM
I will weld in the O2 bung on the collector.
Old Oct 2, 2007 | 09:56 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Tuning shouldn't be an issue.......... For most of us it's an fitment issue, but you would have lots of room underneath a half ton!!!!!!
By the way, long tubes make more torque
Old Oct 2, 2007 | 07:11 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
yeah you wont need to start worrying about the tuning unless youre swapping camshaft, cylinder heads, intake manifold etc. headers wont make much, if ANY difference at all for the stock computer and how it runs/fuel economy wise. you probably will get better gas mileage with the more free flowing exhaust manifolds than if you kept the stockers.
i recommend hooker headers, i have the super competition long tubes on my camaro... but i have ground clearance problems, you wont.
Old Oct 2, 2007 | 07:42 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
I just installed hedman long tube headers with 2.5" true duals into bullet mufflers that dump before the axel. Its runs great. No tuning and no problems so far.
Old Oct 7, 2007 | 01:32 AM
Pat Hall's Avatar
Yeah, consider it a blessing that you can actually run the long tubes without the clearance problems they have when going into a stock thirdgen. There's really no downside to your situation. Lots of thirdgen owners want to run long tubes, but dread the clearance problems. As long as you install the 02 sensor, you shouldn't have any issues. Sometimes you have to run the 3 wire, heated 02 sensor though, since the collector on a long tube header is further down the exhaust path, where the temps aren't hot enough sometimes for the sensor to read properly.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
italiano67
Dec 11, 2016 09:21 AM
Sanjay
Aug 12, 2015 03:41 PM
