Camshaft Opinions
Old Oct 2, 2007 | 04:11 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Camshaft Opinions
I have a 85 Iroc 305/TPI,700r4 and am going to pull heads and do a standard valve job and install Hooker 2055 headers. I need info on what cam kit to use replace the stock one with and not be a problem as I am going to use the stock TPI setup and also not create issues with the stock ECM. I am going to have the injectors cleaned and serviced and replace all gaskets and o-rings on the TPI unit. I also will replace timing chain and gears. Simply looking for the best I can expect without going to a complete rebuild or adding aftermarket heads. Any info or comments will be appreciated. Badman
Old Oct 2, 2007 | 04:49 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Re: Camshaft Opinions
https://www.thirdgen.org/forums/tech...-camshaft.html
Old Oct 2, 2007 | 07:15 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
i would recommend keeping the camshaft under 210* duration, and about .450 lift
that still might be too much for the 305, i dont know because ive never modded a 305... went 350 or a 383 :P
Old Oct 5, 2007 | 06:08 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
i had a big cam in my 305 tpi. ran pretty good. comp cams 12-262-4 if i remember correctly. http://videos.streetfire.net/video/a...075f22047d.htm
with magnaflow exhaust. sounded soooo ****ing sweet...
Old Oct 7, 2007 | 01:12 AM
Pat Hall's Avatar
The Crane Compucam series are a good upgrade over the stock cam that are guaranteed to work with the stock programming. One of those will definitely be an improvement over the stock cam. If you go much wilder than that, you'll have to deal with a custom prom chip to make it run decent.
Old Oct 9, 2007 | 09:09 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
the cam i used in my 305 is in my sig.
I'm VERY happy with it!
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
