IAC checking
Old Mar 21, 2001 | 08:14 AM
max87Camaro's Avatar
IAC checking
Can someone tell me, how to check IAC valve? My cars gas mileage is bad and IAC valve does't work. I have cleaned IAC, it still don't work. I have replaced it with another (used) IAC, it still does not work. Can I check (with some tester, connecting 12V to IAC valve or stmh?), is the probrem in the IAC valve, in wiring or in ECM?
I measured the IAC valve cable voltage, it was -12V/+12V/-12V/+12V (in order of IAC valve pins). Is that OK? If I could get right voltage number, that IAC needs, can I connect this voltage to the IAC and check it that way. Am I right? Maybe you can help me, as I have seen, there is some experts.
Old Mar 21, 2001 | 02:39 PM
billste's Avatar
Vader posted something that may help you with Throttle Minimum Air Position, Idle Air Control Cleaning and TPS adjustment on 3/2/01. Here is the link: https://www.thirdgen.org/messgboard/...ML/006241.html
[This message has been edited by billste (edited March 21, 2001).]
Old Mar 22, 2001 | 01:23 AM
Yes, I have read that. This is very good information, but there's nothing about checking IAC valve (does it work or not) That's way I am asking...
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
TBRays98
Sep 6, 2015 05:05 PM
greenyone
Sep 2, 2015 03:39 PM
