TPS and Code 34
Old Mar 21, 2001 | 11:20 PM
Steve R's Avatar
TPS and Code 34
A few days ago someone on here said that an improperly set TPS could cause code 34 to come up. My TPS is a month old, and when I plug my scanner in it says .58 volts. Is that too much? The book said get it to .54-.56 but that was as close as I could get it!
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old Mar 22, 2001 | 06:22 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
.58 vdc is fine, just as long as you don't go above .63 vdc you shouldn't have a problem. What book told you .54 - .56? The actual allowances are .54 +/- .075 vdc (straight from the GM Manual).
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Mar 22, 2001 | 11:39 AM
Iroc Detroit's Avatar
On my 85 Iroc code 22 is for Tps and code 34 is for mass air flow sensor. Check your repair manually to make sure its the code. When I got code for mass air flow it was because the air duct between MAF and throttle body was not sealed good and was sucking in air.
Hope this helps but like I said your codes could be different then my 85.
1985 Camaro Iroc Z
305 Tuned Port Injected
Old Mar 22, 2001 | 12:22 PM
Car: 1985 Trans Am
A misadjusted TPS can throw a MAF code also... I chased a code 33 a while back until Shane Soldice sent me an article about how the TPS works with the MAF in reporting to the ECM. If the MAF shows too much/too little air coming across at a given throttle position (according to the TPS if it isn't adjusted right) you can bet your bottom dollar you will get a code 33/34. You would probably get a code 21/22 if there was NO signal or a very weak signal coming from the TPS.
Old Mar 22, 2001 | 05:12 PM
Steve R's Avatar
Haynes said it must be between .54 and .56
Thanks for the advice, I'll check out the ducting when I get home and it finally stops raining and let you all know what happens!
p.s. The throttle lags a little when I jam the gas from a dead stop every now and then
[This message has been edited by Steve R (edited March 22, 2001).]
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
