TPI assembly?
Old Oct 5, 2007 | 08:12 PM
77 vette's Avatar
Car: 1977 Corvette
Engine: 383
Transmission: th350
Axle/Gears: 336
TPI assembly?
I've been trying to assemble my TPI on the bench prior to installing it on to the car, I can't find the sequence to this, the runners seem to bind up into my fuel rails.
It is a powder coated 1990/91 Accel base with Accel high flow long tube runners, a Accel reworked plenum and Corvette fuel rail.
Is there a good web site out there that might help me?
Old Oct 5, 2007 | 09:16 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
Re: TPI assembly?
how do they "bind up" with the runners?
a picture would be great if you can get one
Old Oct 6, 2007 | 12:42 AM
77 vette's Avatar
Car: 1977 Corvette
Engine: 383
Transmission: th350
Axle/Gears: 336
Re: TPI assembly?
I can't do pictures. I have never assembled one of there as I have just finished getting all the parts together. They are riding/binding hard between the out side of the fuel rails and the inside radius and lower flanges of the runners during assembly. I think they will clear when assembled if I trim some material off the runners (so much for the new powder coating). I'm going to tear it apart again tonight and try a different sequence, I think I need to locate (but not bolt down) the runners, fuel rail and plenum and tighten them all together alittle at a time.
Old Oct 6, 2007 | 11:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: TPI assembly?
There should be no binding whatsoever.
The only sequence of assembly would be:
fuel rail on manifold
then runners on manifold; don't tighten
then plenum on runners; don't tighten
tighten lower runner bolts
tighten upper runner bolts
Old Oct 6, 2007 | 09:44 PM
77 vette's Avatar
Car: 1977 Corvette
Engine: 383
Transmission: th350
Axle/Gears: 336
Re: TPI assembly?
Thank you, I had a neighborhood party in the back yard last light and didn't get to it. Tonight I will try it again.
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
gixxer92
Sep 1, 2015 04:32 PM
Sanjay
Aug 12, 2015 03:41 PM
