How do I remove injectors from fuel rails?
Old Oct 7, 2007 | 08:36 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
How do I go about removing the injectors from the fuel rails? I see they have some sort of clip retaining them but can't figure out how to release it and I dont want to break them...
Old Oct 7, 2007 | 09:09 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
Re: How do I remove injectors from fuel rails?
pull the clip out
Old Oct 7, 2007 | 09:27 PM
89RsPower!'s Avatar
hmm yeah the clips at the bottom to the manifold came right out but the ones holding em to the fuel rail look different.. you're probably right though, I'm doing this in my basement and the lighting really really stinks..
Old Oct 8, 2007 | 06:12 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Be sure and turn the clips about a half turn before trying to pull out injector. They don't like to come out after being there for a while.
Old Oct 8, 2007 | 08:54 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Yes. Turn them about a half of a turn. Won't be able to turn them further. Be careful though. They're not very strong. Very easy to break or bend. A small flat blade screwdriver works well for turning them.
GM still carries them so at least you won't be totally screwed.
Old Oct 10, 2007 | 10:02 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Apply some lube where the injectors sits in the rail and on the lock rings. Makes it much easier to spin the lock rings and pull the injectors out of the rail.
Andrew6.688
Dec 13, 2015 10:59 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
3rdgenparts
Aug 8, 2015 07:09 PM
92projectcamaro
Aug 6, 2015 01:20 PM
