w/ mods done to my car what mpg do u think i might get?
Old Mar 21, 2001 | 11:34 AM
vortech305's Avatar
the mods are in the sig. below other than that i have replaced every single thing u can think of for the TPI ingluding emissions and electrical. I have 3:23 gears in the back car weighs about In the low 3,000 lb area. What might be my mpg in local and highway.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 22, 2001 | 10:52 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Be rare...buy a 335 stroker crank. Get pistons made for 5.7" rods. replace the flywheel nd damper and balance. You already have been bored over. That engine won't make much more high-end horsepower, but will make a ton of torque (which is what you need on the street, anyway).
A 350 conversion might not be a bad idea, but I see you've already inversted $$$ in your 305 into some 305-specific parts...a 350 or 383 swap would give you alot more HP with maybe a small loss of mileage. Only other thing I can think of off the top of my head is a windage tray, a rocker stud girdle or a blower. I'm sure there's more out there, will make other posts as the ideas flow in.
Old Mar 23, 2001 | 01:56 PM
vortech305's Avatar
I think someone who has invested time,money and thought into my 305 is pretty rare. I doubt theres one person in this place whos spent as much as time and money into a 305. Im not really interested in running 10 sec. on the quarte mile. And since im about to run low 13's with a little 305 i think i did a job well done. Thanks oh what are my miles per gallon.
92' camaro
Soon to come!!!
Other car;
Old Mar 23, 2001 | 03:21 PM
f-bodysucks's Avatar
you have impressive setup and lot of miles ahead i'd add underdrive pulleys, those simply add horse power and you'll get better mileage. that's win-win position.
what kind of cam you'll be running?
Old Mar 24, 2001 | 12:15 AM
vortech305's Avatar
I would use underdrive pulleys but im really scared about cooling and charging problems. People have told me no theres no prob and others say there are lots of prob. Im just afraid to spend 157.00 for the three piece and find out i have those problems. One more thing if i buy it should i buy all three,two or one and how would i know what type of belt i need since the pulleys are smaller. Posting the cam specs is a pain but im sure u ve heard of it. Its accel's cam from lingenfelter part #74211.
92' camaro
Soon to come!!!
Other car;
Old Mar 24, 2001 | 01:48 AM
SLOW91TA305's Avatar
Hey Vortec...
I have a 305 trans am...i'm just curious how much the mods you put in cost. I'm unable to swap my engine and I want get that little sucker as fast as it will go.
91 Trans Am Black on Black w/ T-tops
305 TPI
--no mods...yet
Old Mar 25, 2001 | 10:44 AM
vortech305's Avatar
Well u have a better chance of making more power than me since u have a speed density system. All my mods was pretty expensive considering it took my a year of finding places that were the cheapest i can find. I really cant recall the exact price on parts.
edelbrock base=$346.00(summit)
Accel cam=$275.00 (From lingenfelter himself)
Corvette heads=paid $450.00 for both heads which were rebuild and an additional $250.00 for porting and polish)
edelbrock headers=$308.00(had some mild porting done inside)
catco converter$49.00(free flowing catalytic converter from summit its a 3 inch single universal)
Flowmaster Force II system=$275.00(3 inch piping to an 80 series muffler and has dual 3 inch stainless steel tips.
U can port the plennum yourself.
ignition is up to u
get the airfoil at SLP for 29.95
injectors i bought from summit(ford racing injectors,yes i said ford. Dont go more than 19lb injectors)
Oh yeah the corvette heads work much better on a 305 than a 350 especially if there ported. Theres a bunch of other stuff but its a long list. If u need more info email me or write another post and ill get back to u.
92' camaro
Soon to come!!!
Other car;
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Wade787b
Sep 29, 2015 01:15 PM
matthew911
Aug 12, 2015 09:38 AM
