Anyone have a vaccum canister on their setup
The reason I ask is that, I'm trying to improve my idle when I come to a stop. I have a pretty large cam in my 305, it runs well, but I sick of stalling when i come to a light sometimes. I was told that a vaccum canister will solve most of the problem. My whole setup is kinda on the extreme side as a 305 goes, and yes I have a custom prom, or maybe I can't fix what I've done and I'll have to live with it. Any thoughts anyone?
88'TA 305TPI 330HP, NATURALLY ASPIRATED, PASSES N.J. EMMISIONS. "I AM JUST THAT GOOD"
Here's my list of mods: Melling high volume oil pump, Moroso 6qt oil pan, SLP cam 218I 224E @114lobe seperation, Comp Cam RR 1.6's, World product torquer 305 heads, Big Mouth intake, 24lb injectors, ported plenum, Large Tube runners, 52mm TBw/airfoil, march underdrive pullies, high volume H2O pump, Double roller timing chain, Ported MAF sensor and air box, SLP 1 3/4 headers bolted to a Catco high flow cat and flowmaster exhaust. I also have a 160 thermostat modified and a Hypertech 180 fan switch. I am using an Accell super coil, with Accell 8.8mm wires and Bosch Platinum plugs. I have a custom Prom(not Hypertech). For fuel delivery, I have a high volume intank fuel pump and an AFPR set at 48psi. Rebuilt my 700r4 with B&M rebuild kit and shift kit W/ a 2400 Stall Converter. I have the aluminum Driveshaft and the BW 9 bolt rear w/ 3.27's. I have all new rear suspension parts from Global West including Sub Frames and Eibach springs. All emission parts are hooked up and running. My T/A has the WS6 package so I have the largest Sway Bars that came stock. Any questions let me know
