Slow 305
Old Mar 23, 2001 | 06:08 AM
SLOW91TA305's Avatar
Slow 305
I'm just curious to know how fast can I get my 91 TPI 305 trans am. It's a slug right now and I'm unable to swap the engine. What are some realistic e.t.'s?
91 Trans Am Black on Black w/ T-tops
305 TPI
--no mods...yet
Old Mar 23, 2001 | 06:35 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
It depends how fast u want it and how much $$ u want to spend. There are lots of things u can do, go to the Tech Section https://www.thirdgen.org/newdesign/tech/index.shtml there is ALOT of information in there and should be read before modding so u know what u are doing.
Looking For:
87 IROC-Z28 350 TPI: The car I want.
84 TRANS AM 305 H.O.: Another car that would be OK to own while I look for the IROC-Z!!
Old Mar 23, 2001 | 08:34 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
My 92 Z28 convt runs 14.5 all day with the following mods:
alum drive shaft
Tb coolant bypass
ported intake, plenum, runners
Dynomax catback
hollow cat
Centerforce clutch
Thats it! My best time was a 14.21@96mph.
That was with stock Eagle GA tires and 3:08
rear. The car also put out 220rwhp on the dyno at Super Chevy Gainesville. Not bad for an engine rated at 205 from the factory!
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 23, 2001 | 03:46 PM
MouseCamaro305's Avatar
with a 305 TPI you should be able to get tons of power out of it with a little nitrous, I installed a 150 shot nitrous kit from NOS and its got gobs of power and I'd venture to guess it runs somewhere along the lines of low 13's with the 2.73 gear in it, since I'm not sure about your budget I'd say nitrous, gear swap, something simple like that should get you a little quicker
Old Mar 24, 2001 | 01:36 AM
My 305 is kinda rough right now...it burns a quart of oil every 2wks. i can easily afford most mods. i wouldn't mind spending up to a grand to get my car into 13's. My engine has 120k on it. Would nitrous be a viable option?
305 TPI
--no mods...yet
Old Mar 24, 2001 | 03:26 AM
The ODB's Avatar
build a 383 and put nitrous on it.
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
* vizit miy homepayge * http://www.geocities.com/trailerparkpage/
Old Mar 24, 2001 | 03:36 AM
Administrator
I don't know about making that engine fast, u should fix it and stuff before u do anything.
Looking For:
[This message has been edited by IROCZTWENTYGR8 (edited March 24, 2001).]
Old Mar 24, 2001 | 06:26 AM
Nitro Don's Avatar
The first time I ran my 305,it ran 15.6 @ 87mph.
Best time to date has been a 12.4 @ 109mph
Iv'e done a hell of alot of work to it this winter,and I'm sure I have a mid 11's 305.
I cant wait to get it back together and get it to the track.
Don
Old Mar 24, 2001 | 11:11 AM
Red Demon's Avatar
<font face="Verdana, Arial" size="2">Originally posted by SLOW91TA305:
</font>
my camaro was slow as ****.. check your rear end too.. Mine was like some super economical piece of **** designed to get good highway miles.. kicked that to the corner and put in a 3.23.. not the fastest car in the world, but more of a kick then a 2.something... You may wanna check that out and see if that could be some of the problem.. As for making my car a faster car in the world.. as soon as I get me the money I'm going to have lots of fun with it..
Hey feel free to chat with me on AOL IM if you wanna.. Darkhal2000! Also if you wanna join my webring gimmie a yell at my email addy. I'm always looking for third gen's to add.
My site, http://www.personal.psu.edu/users/j/m/jmj211/index.htm
Old Mar 25, 2001 | 01:22 PM
MrJ's Avatar
MrJ
it sounds like your engine is a worn out POS. I have the same car and engine and ive got no problem with its performance... despite the 2.73 gears.
If you are burning that much oil, the best thing to do is to get a rebuild... actually screw that, don't rebuild a 305... get a 350 and put the TPI on top. If you build up the 350 a little, and port the TPI... easy 13s once you get everything together.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Mar 25, 2001 | 09:58 PM
Stell1579's Avatar
well my 305 gives me a nice kick, it doesnot have mutch past 4.5k or so but hey thats what stock 305s do. now you said you loose a quart every 2 weaks? first check for leaks, i am loosing that mutch too but it is because my oil pan seal is leaking. now, if yo ufind a leak fix it, i have 122k on mine and its all good, if you ar eburning oil, (does the exhaust have a blue tint to it) might be valve seals or something liek that.
now if you decide to pull that moter and drop a 350, everything will interchange (except the longblock, block, pistons ,crank,heads,cam)
but yo uwill need the knock sensor from a 350, a set of 22lb injecors (305 is 19lb) and the chip in the computer for a 350
good luck and welcome to the board there is alot of information here just search for it, you will learn alot
-Stell
1988 IROC-Z 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans, K & N, SLP AirFoil,180 Thermostat+ Temp Switch, Relocated MAT, Cold Air. ,MSD Ignition wires and a few other misc goodies
1988 Pontiac Trans Am. 305 TPI Beyond MINT Condition. Dynomax Catback
Old Mar 26, 2001 | 09:42 PM
DannysZ28's Avatar
If you're willing to spend the grand or so, get a crate GMPP 350 and spend a few more dollars on an exhaust, filters, top end stuff. That alone should show a difference.
1985 Camaro Z28
minor mods, wires, filters, etc., Accel SuperCoil/cap/rotor,
305 bored .030 over, new pistons, cam, lifters, timing kit, water pump, high-flow cat (3" out), Dynomax Afterburner muffler (2.5" out), O2 sensor, MAF sensor, 160W JVC head unit, Rockford Fosgate Punch 360 amp, 2 JL10W0 subs, custom box.
"You may laugh in the face of fear, but it'll be a nervous, unconvincing little laugh."
Old Mar 27, 2001 | 08:56 AM
OK, I would love to swap out that engine. But I have no garage or space to do it in. Thats only an option if i pay someone else to do it.
So does anyone know how much that will cost?
305 TPI
--no mods...yet
Old Mar 27, 2001 | 10:29 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Get a 350, clean it up, chage bearings, put in a mild cam, port the TPI, and do some tuning. This should get you into the 13's if you can get someone to port those 305 heads. Ask The ODB, he knows about 305 head porting...
GouldyGTR
Sep 7, 2015 09:05 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
