Optimum engine coolant temp question
Old Mar 26, 2001 | 08:38 PM
Eighty5TransAm's Avatar
First off what is the temerature the engine should be running for maximum ecomomy and preformance? Second, what if you could make your computer think it was running at this temp all the time? Would this mess up other sensors? If so which ones? Ive solved the problem about the cooling fans, i have a seperate adjustable thermostat, plus a switch in the dash, so cooling isnt a problem. Has anyone done this, or thought of it?
Curtis
Old Mar 28, 2001 | 06:48 PM
AfootVoyager's Avatar
i dont know what the optimum temp is....i have a 160 degree stat with a 3 row rad. and wired the fan so that it stays on all the time....mine runs between 135-140 degrees no matter what...
Old Mar 29, 2001 | 05:04 AM
The ODB's Avatar
Chevy SB's generally produce maximum power on the dyno @ 170F degrees.
Maximum fuel economy would come at a much higher temperature.
Old Mar 29, 2001 | 02:40 PM
theformula's Avatar
160 is way to cold, especially in winter. These cars run well from 175-195 degrees.
By the way, in the winter here...my 170 stat ran at 176degrees all the time.
Also, with colder motors (internally too), you are more prone to knock.
Old Mar 29, 2001 | 05:33 PM
so is there a way i can make the computer think its running 170-175 all the time?
Old Mar 29, 2001 | 06:57 PM
BigMike 92 Z28's Avatar
Mine is usually at 168 or so but if im driving stupid it will get up to about 180 or so
1992 Z28 W/5.7L. Teal with unpainted cowl hood,18" Billet Specialities Rims,Eibach Sportline Springs, Leather int., B&M Mega Shifter, Headman Headers, Flows,No Cats,K&N,HyperTech air foil,Custome Burned Chip,MSD Ignition,Shift Kit, Billet Corvett Servo my Back License plate reads "ALL UL C"
Here's a pic of my car
http://www.geocities.com/jonnyarson/maro.jpg
" WHAT DOES THE BACK OF A MUSTANG LOOK LIKE "
[This message has been edited by BigMike 92 Z28 (edited March 29, 2001).]
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
