Fuel pressure setting for going 22lb -> 19lb injectors?
Car: 92 Z28
Engine: 357 TPI (L98)
Hi all, I've been away a while. I learned long ago to use the search function first, but the new beta is awful. Also, the site seems to be running quite slow tonight. So I thought I'd go ahead and ask.
I got away from my 92 Z28 (350 TPI) for a while and am back to it. One of the last things I did was get the Ford Motorsports "yellow-top" 19lb/hr fuel injectors (for quality). I knew I'd have to bump the fuel pressure, and I recall doing the research and having a target figure in mind - but then I stopped working on the car for a while.
Soooo, now I'm back to the car, and I finally got an AFPR, so how should I set it to compensate for the lower flow rate?
Thanks, everybody.
Thanks, everybody.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Fuel pressure setting for going 22lb -> 19lb injectors?
Thanks, everybody.
Thanks, everybody.
Car: 92 Z28
Thanks for the reply!
Ok, follow-up question: I intended to raise the pressure to the "48-50" psi range for stock injectors, because of the performance increase everyone talks about. What would I set the pressure at with the 19 lb/hr injectors to achieve this?
Thanks!
Thanks!
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
