Oil Cooler
Old Mar 28, 2001 | 03:31 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Oil Cooler
Okay, I am hoping someone knows what this thing is. It looks to me like an oil cooler. It has an adapter in between the oil filter, and the block, then 2 big lines coming off of it going around the front of the oil pan, then 1 line goes up to the radiator just below the radiator cap, and the other one follows the frame rail to the fire wall. Right about where the #4 spark plug is, the line T's off and goes to a black thing that is part of the emmision contol I believe. BTW, this is not a B4C, or 1LE Camaro. It is just a 91 Z-28.
Thanks,
Joshua Johnston
1991 Z-28
Flowmaster
K&N
305 / 5spd. (Temporary)
Old Mar 28, 2001 | 03:44 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yes, an oil cooler. I just removed mine. Total 100% PITA if you have to drop the oil pan to do a cam swap. There are also some horror stories of them getting plugged.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
[This message has been edited by TRAXION (edited March 28, 2001).]
Old Apr 1, 2001 | 10:00 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i just bought a 5.7 TPI that i'm building up to replace my 305 TBI.is it worth it to hook up the oil cooler that can on the motor?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Apr 1, 2001 | 10:43 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I would consider yourself lucky. A good friend of mine has a '92 T/A WS6, and his option codes depict that he should have an oil cooler, but there are no signs of it anywehre. I even ran his VIN through GM to verify he should have gotten the oil cooler, and he has nothing.
As for it plugging up, I would have to say 75% of the trucks I work on at work have an oil cooler, and never seen a problem with them (other than ocassional leaks). To remove them for service, its just two bolts, a gasket and an o-ring, nothing real hi-tech.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
