Finished with the Engine, with these mods will the 305 injectors be okay??
Old Mar 31, 2001 | 08:27 AM
Chris Sartori's Avatar
Hi All,
Finally have the 350 together. Heres the combination I installed. Will the stock 305 fuel injectors run properly?
TPI(L98)off of 91 Camaro
Sportsman II Cylinder Heads
-200CC Runners
-72cc Fast Burn Chambers
-2.02/1.60 SS Valves
CompCams Compucam 12-404-4
-lift .464 Int & Exh
-lobe seperation .114
New Flat Top Pistons
Recon Rods
Turned Crank
Hi Vol Oil Pump
Double Roller Timing Set
Thanks,
Chris
Old Mar 31, 2001 | 08:43 PM
Kyle F's Avatar
hey will be fine, try setting them at 48-50PSI check my Sig, I am running 46psi and turning a decent 13.9 1/4 on 19# injectors(from the 305). Its better to install a bigger fuel pump and crank up the Fuel pressure than to goto 24# injectors unless you really need them. It all depends, but your engine seems like you could pull it off.
THough if I would get the AFR heads I want I would bump mine a little higher.
If you want a set of 24# inectors I have a set of SVO 24#'s that have never been installed that I will sale for $170.00, just email me at teltubbie98_99@yahoo.com if you want them.
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil,MSD Wires, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added.
Stereo has 2 Clairion Pro Audio dash plates, 2 Sony 6X9s, 2 Kicker 12's in a custom Carpeted box with a custom amp rack Holding 3 MTX 280 Amps, and a MTX electronic Crossover all wired with EFX cable.
Asking $4200 with all extra Parts that are needed to fix most apearance flaws. ie Complete hatch and wing from a 91 GTA
http://geocities.com/feltsb/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/2 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
Kyle F's Avatar
thats teletubbie98_99@yahoo.com
Old Mar 31, 2001 | 09:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Chris Sartori:
Hi All,
-200CC Runners
Recon Rods
Turned Crank
Hi Vol Oil Pump
Thanks,
Chris
</font>
just seems odd to me to do all that work and then at the last minute, cut corners. Why not investigate doing your own proms, run some 24 or 30#/hr injectors and have lots of fun. Stock cal ain't even close for that.
Old Mar 31, 2001 | 11:12 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I read (in a book on TPI) that 19 lb injectors are good for up to 400 hp. So I think you'll be Ok with the injectors. But grumpy's right, a custom prom might be a good idea.
Old Apr 1, 2001 | 01:42 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I say just get the 21#/hr injectors and be done with it!! The 350 TPI engines came stock from GM with the 21# injectors afterall!! I think I'm just gonna go with 24# SVO's and an aftermarket Ed Wright Fast Chip in my 355!!
Just my opinion!
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Soon to upgrade to a 355 TPI, Stock TPI ported, 24#/hr SVO injectors, Hedman Shorty Headers, Dart Iron Eagle heads or GM LT4 heads, XE262 Cam ground on a 114 LSA, Moroso Blue Max Plug Wires, external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
Old Apr 1, 2001 | 01:54 AM
<font face="Verdana, Arial" size="2">Originally posted by Grumpy:
</font>
I have not had a chip burned yet Grumpy. I had a set amount of cash to get things as far as I could. Then I had to look into options of saving a few bucks. When I have the chip burned, is the chip set just for a specific injector size? Or will it be able to work with larger injectors?
Thanks for the feedback and help!
Chris
Old Apr 1, 2001 | 03:01 AM
<font face="Verdana, Arial" size="2">Originally posted by ViciousZ:
I read (in a book on TPI) that 19 lb injectors are good for up to 400 hp. So I think you'll be Ok with the injectors. But grumpy's right, a custom prom might be a good idea. </font>
Hi ViciousZ,
Thanks for the reply. I have not had a chip burned yet. I have a speed density TPI and need a new chip anyway that will dissable VATS, etc. I am not sure what information the chip burners use but maybe I can get by with the 19# injectors.
Thanks,I appreciate the feedback,
Chris
Old Apr 1, 2001 | 03:06 AM
<font face="Verdana, Arial" size="2">Originally posted by Kyle F:
</font>
I have not had a chip burned yet. I am not sure what information they need or how much controll they can make in the prom. If they recommend bigger injectors I will be emailing you late next week! I dont want to run the engine to lean.
Thanks for the reply and the feedback!
Chris
Old Apr 1, 2001 | 01:38 PM
Kyle F's Avatar
Ok, but a custom prom is another thing you will eventually need for top performance, I just understand what you mean about doing it on a limited amount of cash. People act like if your going to do something you have to do everything 100%, they sometimes forget about the $$$$ of doing everything to the hilt.
Old Apr 1, 2001 | 03:26 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
For what its worth, I run 19 lb/hr injectors with a modified TPI (heads, cam, ported intake, 52 mmTB, etc.). I had to turn up my fuel pressure to 55psi to get the block learn down to 128. I have a MAF setup as well, so a bit more tolerant.
I would suspect with a speed density setup, you will definitely need more than 46 psi to avoid running lean at WOT. Keep in mind, not all injectors will flow more at higher pressure. There is a limit at where an injector will struggle to open against the pressure and therefore have less overall flow. The worst case with higher presure (high as in the 50's) is that the injector balence could be off, some will flow more, some will flow less. This would result in a few cylinders running lean. Ok worst case I realize, but you did just spend a whole pile on that new engine right?
Hook it up to a scanner and monitor what it's doing when you get it running. You can always change injectors later.
Mark.
[This message has been edited by Mark_ZZ3 (edited April 01, 2001).]
jhawkeye
May 25, 2022 06:33 PM
1nastygta
Oct 28, 2015 08:51 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
