help!!! heads don't match intake
i have an 87 tpi 305 and i just got vortec fastburn heads for it and i had them milled down to fit. my intake manifold does not match up to the holes quite right , i was wondering if they have a gasket that will make it fit or if i have to buy a whole new intake? and if i do buy a new intake will my old tpi system fit up to the new manifold?
You should've searched the archives for info on the Vortec style heads - there have been a lot of posts regarding Vortec/TPI. The only way to get your stock intake to match the heads is to weld it then port it and have it milled - and it still won't be a good match. SDPC is "supposed" to be releasing a TPI base intake for the Vortec heads next month - although that's been the case for a year and a half.
Search for Vortec and you should find all the info you want about why your parts don't match and what your options are.
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
there has been some talk about it being in the $450-500 range for the base... but it will be able to retain the egr for emmissions...
i am waiting for this intake also...
later,
Chris
later,
Chris
