carb. to TPI swap
carb. to TPI swap
i Have a 87 IROC that got totaled a few day's ago. And I have purchased a 86 Trans Am
and I want to pull the the 350 Tuned port from the IROC and put in the T/A. I know I'll have to change the fuel tank and the line's. And the wiring and computer. can anyone tell me what if any of this off the Iroc will work on the T/A.The T/A was 305 with a carb.
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
I would just start swapping parts...
i dont think you need to change the gas tank... but it will probly be easier to do it that way since you already have the parts...
Fuel Lines
Fuel Pump
Computer
Harness
Sensors
and the 350 TPI of course...
you have quite a project on your hands but one i will hopefully be tackleing sometime next year...
TPI 84 TransAm...
later,
Chris
Fuel Lines
Fuel Pump
Computer
Harness
Sensors
TPI 84 TransAm...
later,
Chris
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I'll say it again. There are missing wires in the instrument panel harness that need to be added or all your work will be useless. I have a diagram I made that clearly shows the missing wires. One set that are critical are the fuel pump wires that run back to the tank, it would be if you did a carpet swap at the same time.
E-mail me if you need the diagram, well nevermind here's a link to it for everyone. E-mail me specific questions about it, I don't mind.
http://members.home.net/millicanga/files/TpiWiring.jpg
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
86 Camaro Sport
My Camaro Project
Sanjay
Aug 12, 2015 03:41 PM
