Head mods, LT4 Cam in a 305
Old Oct 15, 2007 | 11:20 PM
96LT4c4's Avatar
Car: 99 HOSS 6 Speed
I have been working on my 081 casting 305 heads (for my boat). Machined down stud bosses and tapped for screw in studs, cut down the top of the valve guides for more lift, gasket matched, and, ported the S**T out them. Also did a 5 angle valve job and unshrouded the valves.
Does anyone know if you need to mod the pushrod holes in the heads or not? I am waiting on a set of 1.6 roller rockers, so I havent been able to check. If I do then I might just drill them all the way out and run guide plates.
Old Oct 15, 2007 | 11:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Head mods, LT4 Cam in a 305
i dont think i've heard of anyone haveing pushrod hole problems. guideplates tho are fairly cheap and work ok, so its a safe bet.
i've seen many hotcams and other cams with 1.6 rockers and not seen a problem with pushrod holes/clearances
Old Oct 15, 2007 | 11:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Mine fit fine. I have heard of others having to drill though. Date code on my heads indicated december 1989. LT4 cam and 1.6:1 roller rockers
Old Oct 17, 2007 | 08:48 PM
96LT4c4's Avatar
What did you do to get your factory steel valve covers to go on? The rockers I bought have really wide bodys and are hitting the steel braces inside the covers. Did you have to trim those out?
Old Oct 17, 2007 | 08:52 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
yah u need eier narrow bodied rockers, or some cutting and grinding, most are against cutting them up but, idone it with no problems.
Old Jun 14, 2012 | 07:45 AM
Ramjet 305's Avatar
Car: 1991 Chevy camaro rs
Engine: Chevy 305
Axle/Gears: 28 spline axle, 2.73
What do you think of a ramjet 305 with an lt4 cam, 059 or 520 casting heads? 1.5 or 1.6 rockers?
Last edited by Ramjet 305; Jun 14, 2012 at 07:47 AM. Reason: Forgot to mention the rocker arms
84z96L31vortec
Aug 20, 2017 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
drathaar907
Aug 6, 2015 04:20 PM
