aluminum driveshaft ?
Old Apr 3, 2001 | 11:15 AM
travsirocz's Avatar
Car: Two 1987 Iroc-Z Z28s
Engine: 5.7 TPI ZZ4 1.6 Roller Alum. Head
Does the gm aluminum driveshaft fit 82-01 camaros with V8. Does it matter if its manual or auto. thanks trav
1987 Camaro Iroc-Z Z-28 with a TPI 5.7
-Ram Air,K&N Filterchargers, Gutted Mass
Airflow Sensor, Throttle Body Airfoil,
Edelbrock TES Headers and Y pipe, Gutted
Cat, 3 inch exhaust, Flowmaster
-Hypertech Thermomaster Chip, 160 deg Stat,
Adjustable Fuel Pressure Regulator
set at 50 psi, MSD Cap, MSD 8.5mm wires,
Accel Coil, MSD 6AL Ignition Box, Accel
Plugs
-Richmond 3.73 Gears, B&M Transpak,
B&M Rachet Shifter, Energy Suspension
Products
-Fiberglass Cowl Induction Hood,
Purple Neon License Plate Frame,
16X8 Rims with BFG 245 50's,
Pioneer Deck, 2 JL 12's in a Q-Logic
Box with a 300 Watt amp
What you can put between your ears,
no one can take away.
Old Apr 3, 2001 | 11:58 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
The aluminum shaft will fit through the LT1 cars...they are all the same irregardless of trans(I know for sure of the 700r4 and T-5....200M trannies may be diff)...the LS1 shafts work I guess...but are bigger in dia and thinner material...have heard they aren't as strong but that could be hearsay...
GregF
87 IROC
Old Apr 3, 2001 | 11:33 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Thats weird that you say that, Why in the hell would GM put a weaker driveshaft in a more powerful car? I want to get a LS1 shaft myself, becuse I always thought a bigger shaft (dia.) would be stronger. But I really dont know either.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, Fastchips custom chip, 3.23 rear gears, white face gagues, and NOS!
Old Oct 17, 2007 | 09:34 PM
tranceemotionz's Avatar
Car: 1991 Chevrolet Camaro Z28
Engine: 5.7L TPI L98
Axle/Gears: 3.23 posi/limited slip
Re: aluminum driveshaft ?
so will a aluminum shaft off a later fbody fit on a third gen... the dealership told me it wouldnt because their different trannys. mine a 700r4 and the ss i think a 406le or something but he said they are different lengths. so is it true or not? thanks
kevin
Old Oct 17, 2007 | 09:42 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I can't tell you for sure if the driveshaft will interchange between F-body generations, but I can tell you that the F-car version of the 700r4 is the same EXACT length as the F-car version of the 4L60E.
That being said, I replaced the 2-piece steel driveshaft with carrier bearing (went out) in my 1983 G20 van (700r4 equipped) with a 1 piece aluminum shaft from a 1995 G20 van (4L60E equipped) and the fit was perfect.
Old Oct 17, 2007 | 09:45 PM
thats helpful cause i guess that guy didnt know what he was talking about cause he said theyre diffent lengths. its just before i go to the bone yard i want to make sure it will fit. i called today and they have one i think off of a 99 or 00 ss and only want 100 bucks for it. i hate dealerships they always try to bs you. i just replaced my trans mount with a poly one and they tried to tell me i have to replace the motor mounts with poly as well or i could tear up my transfer case and what not. sorry to go off topic. but thanks for the info
Old Oct 17, 2007 | 11:27 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The f-body aluminum driveshaft will fit all other thirdgen and fourthgen f-bodies with V8's, and T5, T56, 700R4, 4L60, or 4L60E overdrive transmissions.
I dont know if it fits the 82-83 f-bodies with non-overdrive transmissions.
Old Oct 18, 2007 | 08:14 AM
brian schuetta's Avatar
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
My 83' came with non-overdrive trans and V-8. Used the same driveshaft after putting a TH-350 in it. Used it to make many, as in around 200 twelve second runs on slicks with it. This one was steel. Switched to aftermarket aluminum and saw no solid repeatable gain. Just change U-joints( Spicer ) and put a white stripe on it to check for twisting.
Linson
Oct 24, 2025 02:00 PM
loud91rs
Oct 5, 2015 10:05 PM
