Return Line Pressure?
Old Apr 4, 2001 | 10:22 PM
Steve R's Avatar
On my '80 Camaro, someone told me I can use the original fuel line as my return line. Will that work/handle the pressure?
That would make life easy because I would only have to run ONE line instead of two.
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old Apr 5, 2001 | 02:45 PM
IROCZ88's Avatar
Need some more info!!
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Old Apr 5, 2001 | 04:14 PM
Steve R's Avatar
I'm looking at an aftermarket fuel pump for $115 that makes something like 115 psi. I'll be using around 42-45 of that so that leaves around 70 to be returned, right?
Someone on the second gen board told me that I could simply use the original fuel line that feeds the carburetor now as my return line, so that I only have to run ONE high pressure line from the pump to the fuel rail.
mike_c
Aug 27, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
wayshegoes
Aug 17, 2015 12:00 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
