Problem installing Autometer Fuel Press. Gauge
Old Apr 6, 2001 | 08:13 PM
wickedfbody's Avatar
How have any of you done this? I can't find a damn fitting that goes from the Schrader valve (4 AN), which is male, to the sending unit which is 1/8" NPT (also male). Earl's doesn't have em, neither does anyone else I have tried. I called Autometer and they just told me to call elsewhere.
So, simply put, I need a fitting with two female ends; one 4 AN and the other 1/8" NPT.
Any help would be great.
Old Apr 7, 2001 | 12:42 AM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
A hint that NickD gave me, and I used it with no problems:
Find a Parker or Aeroquip Industrial fitting supply store in your town. Buy a swivel nut 90 degree elbow fitting that has a -4 37 degree flare female nut that screws onto the Shrader valve (once you take out the valve inerds). The other end of the elbow is a -4 male fitting. I then used a 3ft -4 braided hose to go to the sending unit which I mounted on the driver's side firewall cowl (by the relays). The Autometer gauge/hose kit had a fitting in it that was a female pipe thread on one side, and a -4 male 37degree flare on the other that fit on the sending unit.
The local Parker place was open on Saturdays, and the part was about $3. Even if you opt to look for your own combination of fittings, the Parker or Aeroquip distributors can help you.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
[This message has been edited by KevinP92Z (edited April 06, 2001).]
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
