less then $100 mods
Old Apr 7, 2001 | 08:56 PM
camaro6spd's Avatar
less then $100 mods
what effective mods can be added to a TPI car with a cat-back and a quality ignition tune-up that is under $100
Old Apr 7, 2001 | 09:25 PM
Vader's Avatar
Camaro,
If you have some equipment at your disposal, there are many things you can do for under a Franklin:
1. Plenum / runner / base porting 9$30.00 for a gasket set and a few bucks for burrs);
2. AFPR conversion (about 20¢ in parts);
3. Relocated MAT / IAT sensor ($35.00);
4. Cooler thermostat and fan control (about $40.00);
5. Air cleaner box restriction removal;
6. Boxed rear LCAs ($10.00 in 14 ga. steel sheet);
7. Urethane suspension bushings ($80.00 per set, $115.00 for a complete set);
8. Fabricated STB & "wonder Bar" ($30.00 in 1" square tubing and ¼" plates);
9. Sub frame connectors ($28.00 in 14 ga. steel box channel);
10. 1.6:1 roller tip rockers ($90.00 / set);
11. High-flow muffer ($70.00);
Many more if you search the Tech Articles...
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
school boy
Oct 22, 2015 11:47 AM
bigjay89gta
Oct 15, 2015 08:04 AM
Royal_Z
Sep 30, 2015 08:45 PM
